  • 7 Replies
  • 17123 Views
  • 2 Likes
  • 6 In Conversation
WolfEdman
I don't want to receive text alerts.  How do I stop them?
7 REPLIES 7
KristynM
Hello @WolfEdman
I would like to get more information regarding your inquiry.
  1. What kind of device are you using? Andrioid or iOS?
  2. Is the notification you are receiving through the Arlo app, or did you setup text notifications.
As soon as we receive this information, we will be able to provide the proper steps towards a resolution.
I look forward to your response.
Regards,
KristynM
Arlo Support Team
WolfEdman
I am using an iPhone 5.  (iOS)  The notifications seem to be coming from the Arlo App.
KristynM
Hello,
The notificiations being received from the Arlo App are called push notifications.
In order to disable your push notifications on iOS 5, take a look at the article provided below:
How do I enable and disable Arlo push notifications on my iOS device?
The article also describes how you would enable the push notifications as well for future reference.
Regards,
KristynM
Arlo Support Team
Larryagent165
to turn off text messgs...
Yes, you can turn off email....
go to SETTINGS, RULES for the camera in question
down the right page see Send EMAILS to this LIST... click on " > "
Click on the "check" mark to toggle on or off ( green is active )
HIT SAVE ON EXIT
MarkDeman
This solves my problem for my iOS device.
How can I do this on an android device?
Since it's built into the rule, it affects any device.  The alert that is particular to the device is for the iOS/Android apps where you have to enable/disable the alert on that device in the system settings for the Arlo app itself.
