  • 2 Replies
  • 1372 Views
92
If you have 4 camaras, you currently have two default modes.... Armed ( all on ) and Disarmed ( all off )
For one camera ( or two, or three ) you must create a new Mode;
go to MODE, click on arlo base, Right side bottom ADD A  MODE
Click on that and follow the steps to add a single (or more cameras ).
* With above if adding 2 or more cameras, you must first creata a New Mode and then go back and EDIT it to add additional cameras.
Remember;
One one mode can run at a time
Any camera NOT in a mode will be off
Go to the Mode tab, click your base and create one or more new modes.  When you create a mode, it allows you to set up one camera.  If you want to add more camera rules to the same mode, you need to reedit that mode as many times as you have cameras to add.  Now that you have your new modes and rules, click on an appropriate mode to activate it.
