Feature add: Abiltity when one can senses motion and other selcted cameras will record aswell
  • 2 Replies
  • 13667 Views
Warnzie
As the subjects says. Be a great added feature if one camera detects motion the other cameras (selectable) will record as well for the selected desired time. E.g I have 2 cameras, one looking at my driveway and the other my gate house, if say the driveway camera picked motion up the gate house camera would also record. Reason been I find the motion detection to be dicky at times.
You can define a variety of rules that will turn another camera on based on activity of a different one.  So, based on activity on the driveway, you can set a rule up to activate the driveway camera and then a different rule to use the same activity to turn on the gate camera.  Once you have the rules set up, you can add them to a mode (right above Rules in Settings).  Then use the Mode screen to set up scheduling as desired.
Thus, multiple rules assigned to a mode.
RobertRosal
Virtuoso
Virtuoso
As Jeff has stated, that feature is already there.  You will need to create the rules and create a mode to activate them.
-Robert
