how do i reset arlo to pre-programmed mode - motion off'/motion on
  • 1 Reply
  • 10794 Views
akg
can any help?  without deactivating my account, of course.  thank you.
read this first; https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-Modes-amp-how-do-I-use-them/ta-p/32
Then go and MODES/ EDIT ( pencil ) the two MODES...ALL ON will have ALL GREEN Check marks ant end of each camera / ALL OFF they will be GRAY.
remember to save as you exit
If you deleted the modes, then you have to create one first.. go to SETTINGS/MODES hit the "+" sign to add one, call it ALL CAMS ON ( or whatever)
and like above, make sure the camera rules have a GREEN check at the line end to show they are active.
