Does anyone know the spec for PIR reset time on the arlo cameras?
Message 1 of 2
1,734
As to the actual spec of the PIR, that's netgear. if you mean how often does the PIR function, TMK it's a device thats active once motion is turned on and the time between recordings is more controlled by the lenght of time set in the rules than the PIR.
I have found shorter times work for me as a new record will start if motion is still present.
Message 2 of 2
1,721
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
