  • 1 Reply
  • 1673 Views
Rudy
Does anyone know the spec for PIR reset time on the arlo cameras?
As to the actual spec of the PIR, that's netgear.  if you mean how often does the PIR function, TMK it's a device thats active once motion is turned on and the time between recordings is more controlled by the lenght of time set in the rules than the PIR.
I have found shorter times work for me as a new record will start if motion is still present.
