  • 6 Replies
  • 2651 Views
jas0042
I have been trying to figure out how to trigger two cameras if one detects motion.  I see lots of explanations for how to do it but the options don't seem to be where people say to look.  Is this function missing?
Retired_Member
Not applicable
Hi Jas0042,
     I also have been playing with rules. What I would do is create two rules:
* Rule 1: My Arlo > Mode > (Mode Name) > Camera 1 > Motion is Detected > Sensitivity > Camera 1 > Record Video > Send Alerts > Finish.
* Rule 2: My Arlo > Mode > (Mode Name) > Camera 2 > Motion is Detected > Sensitivity > Camera 1 > Record Video > Send Alerts > Finish.
Does this help?
Good luck,
Dave
6 REPLIES 6
Retired_Member
Not applicable
Hi Jas0042,
Does this help?
Good luck,
Dave
do a search above on  " nested rules "
jas0042
Thanks so much!  I knew there must just be a button that I was not seeing.  I suppose there isn't a way to make a custom rule with Geofencing?
Retired_Member
Not applicable
Jas,
There is a way to do Geofencing. It's greyed out on the PC page but available through the Arlo app.
I have yet to play with it...
Regards,
Dave
jas0042
Right, I have played with the geofencing and got it to work.  What I was wondering was if there is a way to add geofencing to a custom made rule
No, it works the other way around.  When using GF, you define the mode you want to use when in and out of home.
