  • 4 Replies
  • 2862 Views
adeel
How do I find out how much cloud storage has been used by the recordings and the available storage space?
steve_t
Master Master
There doesn't seem to be a limit now apart from the 7 days worth of recordings (or longer if you have a subscription)
Yup, no storage size limit as of a year (?) ago.  If you really care, you could download all your videos from a particular day using the Select All capability and check out the total size.
adeel
The Basic subscription plan lists 7 Days of Cloud Recordings but also has a note below of "Up to 1GB Cloud storage."  Did they recently add the 1GB limit?
No, the 1Gb limit goes back to the start in early 2015....
Netgear has not enforce the limit since removal of the usage gauge back in late 2015
