  • 31607 Views
  • 3 Likes
c0mm0
Is there an easy way to change the camera order in app and on webpage other than removing cameras and adding them in a specific order.
For instance I have 3 cams and would like the one at bottom on top. Just curious if I am missing something that would make this easier than removing/re-adding
thanks
While I haven't putzed with it, in Settings is a camera order section where you can move things around.
As J has said...its in the settings-camera order.
It's now just a drag-drop to select order of cameras ...then save
c0mm0
thank you i don't know how i missed that, i think i figured it was another tab to order a camera (as in buy)....lol
appreciate the answers folks
