  • 1 Reply
  • 13458 Views
SarahC
I can't watch videos from the library view online. I get a message that I am using the wrong browser. Which browsers are compatible? I am using Firefox.
Also, when I download a video from the library, it is just a black Quick Time file without content. I am on a MacBook Pro, OS 10.6.8. Is this compatible?
ChristineT
Good morning SarahC,
Thank you for your inquiry! If you haven't already done so, check out this link that provides information on supported browsers.
https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-minimum-requirements-for-installin...
Have you tried Safari for Mac? If so, does this browser work as expected? Do you get any errors when using Firefox?
I look forward to your update.
Best Regards,
Christine
Arlo Team
____
Please click KUDOS or REPLY if you found this helpful.
