  • 3136 Views
MiArlo
I have a camera setup to cover all the area of my livingroom but I get 300 clips of this area a day...  What are some best ways to cover a busy motion area without so many clips of movement and without turning motion off? I still want to cover the area with motion but not run down the battery?
I'd think continuous monitoring would be a better choice, leaving Arlo out of the realm of use.  If Arlo is necessary, you could get someone to maybe modify the camera(s) for a power supply (there are some threads about doing this).
Arlo is better for occasional use rather than continuous monitoring.
You can not use the PIR (motion) sensor to zone off some areas and not others.
In all honesty, if you need 300 video clips per day, the system isn't really designed to do that continuously.  Maybe you could cut down on that time of the motion detect via the schedule.
End result, the way your using the sytem, you may want to look into rechargeable batteries ( cause your going to drain them quickly ).
MiArlo
How would one monitor an area that is busy and still record...  an example might be to record a cashier working on a cash register and still be able to have this information recorded for play back as a recorded clip as proof of cashier pocketing monies?  Thank You for your input!
