How do I leave some cameras armed full time while others on a timer.
Message 1 of 7
4,914
That just means you need to modify or add more modes. Since you want some cameras on at all times and others at only certain times, try this:
Mode 1 - one camera
Mode 2 - all cameras
Now use the schedule. Assuming you want all cameras on at night, Mode 2 would be scheduled from 12:00AM to, say 7:00AM. Mode 1 would then be set frl 7:01AM to 7:00PM. Then Mode 2 would be scheduled from 7:01PM to 11:59PM. This way one camera is on all the time but only the single one would be on for certain times. Modify as needed and even add additional modes to fine tune other time periods.
Mode 1 - one camera
Message 6 of 7
7,990
6 REPLIES 6
You prob have to create Custom Modes,,,, split up the cameras into groups so some can be armed and others not.
Explain exactly what you want and how many cameras
Message 2 of 7
4,909
I have 5 cameras I want 3 on at all times and 2 on a schedual.
Message 3 of 7
4,904
Have you read the FAQs on how to set up custom modes and rules?
Message 4 of 7
4,901
Yes the problem is i have to modes set I can set each mode individual in the schedual each for different times. One is set to on all the time the others a set time. When I set times for the second set it overlaps time set for the first set so that they are no longer on. So now instead of being on all the time it is only on until the other cameras turn on. Not sure how to explain it. It seems times can't overlap between modes.
Message 5 of 7
4,899
Mode 1 - one camera
Mode 1 - one camera
Message 6 of 7
7,991
I figured it out thanks for you help. I set at armed mode for the time I want all cameras on. Then set my custom mode for the times I wanted the other cameras on.
Message 7 of 7
4,895
Android App
Geo-Fencing
89 -
iOS App
Online Web
Surveillance
