Arlo is currently unavailable
  • 7 Replies
  • 3243 Views
  • 7 In Conversation
Uncertain
I just bought an arlo system on weekend. And we've set it up, and are getting notification that the cameras are detecting motion, yet when i click on app i get a message saying arlo is currently unavailable? Does this happen often?
7 REPLIES 7
There have been instances where this occurs but it's usually on a per user basis. Try logging out and back in as well as use a browser. It could be pretty much anything including the phase of the moon.  FWIW, I've had no problems.
Good2U
I get this once or twice per week. Try killing the app and opening again. Sometimes it helps.
Very frustrating!
Also, easiest thing to try is a different browser ( some work well, some are flaky at times )
Atz
I am getting this for the past week. Can not use the mobile app at all. Very poor service. Good think i got only one camera
Atz,
I have addressed this issue in another thread and reached out to you privately in regard to this issue. Please let me know if you need any additional help or have any further questions or concerns.
gypsyjim
Interested in what your solution you had for the "Arlo is currently unavailable".  I am getting it using the app but it
works fine accessing thru desktop.  Also, even from the desktop, if I hit "live" on a camera it tells me it fails to connect
even though if motion is detected, it records fine.
I'd reinstall the app.  Sounds like something is goofy there.
