Arlo App update library
  • 5 Replies
  • 2830 Views
nickgtr35
The new app update does not show previous months, how do i select previous months?
5 REPLIES 5
Viperbird
iOS and Android  app - you can scroll through the dates on top of the Library screen by swiping right to see the previous dates.
Web -  if you have recordings for prior months, a selection appears in each corner above the dates to select the previous month. Note this only appears when you have recordings for prior months so you have to have the premium service...Premier or Elite plan.
nickgtr35
thats strange i have a basic subscription plan and prior to the update i was able to see previous months listed in the library
some older files have been deleted it seems by the new updates and also recycle bin is gone...So since you only have 7 days storage, nothing is in the previous month ( today being the 29th ) to scoll to so it doesn't work.   Housekeeping seems to be right on the date now
nickgtr35
you are right but my camera still shows 10 recordings and the library shows none. They have removed the delete all files function meaning that the camera recording notification and the library are not synced and i dont know how to sync them
Delete all files is still available using the web page.
