Android app urgent bugfix required.
  • 15 Replies
  • 12613 Views
  • 3 Likes
  • 7 In Conversation
nickmobbs
Hi,
Today i have realised that since the update every time the camera's are triggered and i log in using the android app, the camera mode is changed to 'disarmed'.
So i have to change the mode every time.
I do not know if it is the camera's being triggered or the act of logging in to the android app that is changing the mode, i will continue to monitor and provide feedback if i am able to confirm.
If anybody else can test this i would be grateful!
Nick
Update: A fix for this issue was deployed over the weekend resolving this issue. Please let me know if you are still experiencing any related issues.
Thank you,
15 REPLIES 15
nickmobbs
Ok, i have done a little more testing.
It seems the motion detection indicators are randomly turned off, as if motion detection is disabled, however it is not.
For example - With mode set to schedule.
I recieved a notification that the cameras had been triggered....i logged into the website, everything was good, i could see the postman had delivered some mail.
I then looked at the android app, the motion detection icons were off.... I didnt change anything but recieved further tigger notifications when another person approached the house....
I think there is a bug in the handling of the mode/motion detection icon following a trigger event when logging in with the android app.
I hope this can be fixed quickly.
Kind Regards
Nick
nickmobbs
Just had the mode change from a custom mode to disarmed for no apparant reason....
Camera's were triggered (so they were armed!)... i logged in using firefox browser and mode was changed to disarmed.....
I have to say this is making the system really very unreliable, randomly changing mode to disarmed is appalling.
I might as well leave it switched off until a new version is released!
Netgear - please reply and advise what you are doing???
I'm noticing some weirdness, too, such as the running men showing amber/yellow even when no motion is detected in a browser but not in the app.
As for the mode changes, when you select the Mode tab, the display no longer tells you that it's using the schedule but what mode is selected in the schedule.  You have to select your system to see that the schedule is actually selected.
That said, I've had some issues getting the schedule to stick on a base station with a single camera attached where I enabled the geofence.  Turning geofence off and selecting the schedule has had me finding Disarmed actually selected.  I've then selected schedule again and after a few tries it seems to have stuck.  I don't know if this is something to do with the app or browser since I've used both.
sbtyper
I am also having this problem. The base station suddenly becomes disarmed. I changed it back to arm 3 times already this morning. This is so frustrating....
Are you using the app or a browser? Try the other to see if it works better. I can't prove it but I thought using the browser seemed to fix it.
sbtyper
I am using both app and browser. It will automatically change to Disarmed and will show in both app an browser.
I have escalated this issue to engineering for further investigation. I will post an update as soon as I hear back.
Update: Engineering has identified the cause of this issue and are working toward implementing a fix as soon as possible.
mep123
Fyi...I'm having the same issue. Since update of Android app my camera modes are randomly switching from armed to disarmed.
nickmobbs
Thanks for the update, can you provide an idea of timescale please?
In my opinion this update should be the highest priorty for Netgear right now due to the amount of people effected by this.
RabbitPower
I'm having the same issue. Agree with Nick - this should be the HIGHEST Priority for Arlo. Maybe there's a workaround until this is fixed? If I find one, will post.
Thank you,
nickmobbs
Hi James,
Yes i noticed the improvement yesterday, modes no longer seem to change when the camera is triggered.
Thank you for sorting that one out quickly!
I am however struggling to get geolocation to work reliably as i think the android apps on both my phone and my wifes go into a kind of 'stand by' mode when not used for a while.
If you could find a way to prevent the app from going to sleep and not reporting its location until you open the app, it would be much better.
Sorry, but I started a new topic called 'Geofencing - further feedback' within the community feedback forum, in order to provide feedback as requested.
Thanks for your support.
Regards
Nick
Cassidy
Luminary
Luminary
Did you FIX the ANDROID application/software ? I want to know if ALL bugs are fixed before installing it again on my tablets ...For now, I only use Chrome on PC but I still have CVR problems ...and I don't want to add other problems...
Cassidy
What are your CVR issues?  Maybe start a new thread in the Q Troubleshooting forum to prevent clutter here unless it's app-only.
