Just recently I noticed on the camera page it shows zero when in fact there are many videos to view in the library. This is affecting all 4 of my wireless cameras inside & out.I unplugged the base for a minute and plugged it back in with no change. Has anyone else had this happen? Thanks 🙂
As jguerdat describes above the Arlo Team is committed to further optimizing this feature in the future. You can find the full intention of its current behavior here: Arlo media counter optimized
Thank you,
Folks have reported similar things that resolve itself after some period of time.
OK, I'll give it a couple days & see what happens! Thanks for the sugestion.
I'm receiving the same issue, going on since this latest update on 2/16 or 2/17. I receive notification of motion and after a while I go check library with nothing there. When the next motion is picked up, and I look in library, there is the previous video(s). Seems like a cloud issue?
Yes, my system does the same. It shows it's recording, I go to look at the video when it's done & there is no video, but I go back much later and there it is! All the while, my camera still shows zero.
We are aware of this issue and are working diligently toward a resolution. We appreciate your patience and understanding during this process.
Thank you,
Thank you for your response! Also, I wanted to say even though my cameras are set for 30 seconds, sometimes after they detect motion, they will record only 8 seconds up to 28 seconds. Most of the time they do 30 seconds, more than half the time, is this related to the same issue? All of the issues discussed, camera slowing zero recordinds, the video not showing upright away and the length of the recording just began a week or so ago? Thanks again!
Many videos, but count still shows zero.
any estimated time this problem will be resolved? i just upgraded to Premier and the minute that happened my video counts have always been zero. not only that, i'm getting negative numbers (i.e. -5, -10, etc)
yes, when i was on Basic i had the problem and it resolved itself when i logged back in or refreshed my browser.
i also restarted the base station a couple of times too.
It's been told here and in an alert email from Arlo that the counts have been disabled to help with the fix for long lags for notifications and videos in the library. Apparently when the full fix is in place the counts will return.
Dear Arlo customers:
Arlo was experiencing unexpected issues with our cloud servers which slowed the delivery of alerts and video recording for some of our customers. We apologize for the inconvenience this caused.
Because these alerts are critical to our customers, we deployed an immediate solution yesterday (2/18) to timely deliver your alerts and recordings. As several of you noticed, this has significantly improved Arlo performance. However, a side effect you may currently experience is the alert counter on the camera screen disabled and set to 0. Resolving this counter issue and further optimizing Arlo performance is our number one priority at this time and Arlo engineers are working non-stop on this.
is there any way to get the count out of zero.. been this way for 4 days
how did you fix the problem
mine still says zero. what is the solution
So, once they figure out a way how to bring the counter back without causing an overload, we'll see it again after an (app) update.
Thank you,
When
How long
lindallk,
I do not have a specific date for when a fix will be released. We are still working on a resolution and will post an update when one is made available.
Thank you,
