I tried login into my cameras on my I phone but with the authorization code that gets sent to my texts, i cant switch back and fourth between the two and now I'm locked out. How can I get in now ?
Can you try using the pc web browser to login to the my.arlo.com web portal to access the account?
I have the same issue. The text verification takes about 5 minutes to receive, and the website allows 2 minutes. Classic IT design and incompetence issue.
Also, each time that someone leaves the iPhone app to pull the text code, the app closes, thereby requiring a new login, which requires leaving the app. This "loop" recurs until the user reaches the limit. This is a super classic "We did not test the app fully" issue.
Absolutely terrible IT issues.
Did you ever figure this problem out?
I’m having the same loop failure in the app.
>login
>sent one time code
>login page blank again (no place to input any codes)
>login again
>sent one time code again
over and over again.
Having the same issue. The app is closing and will send a code each time I tried to open it. By the time I entered the code it is no longer valid because a new one has been sent again.
Tried using the web browser. Getting this error message - unused second factor auths limit reached.
There is an option to use a different method. Tried using my email and it works.
