  • 6 Replies
  • 3676 Views
  • 6 In Conversation
Gschell
I tried login into my cameras on my I phone but with the authorization code that gets sent to my texts, i cant switch back and fourth between the two and now I'm locked out. How can I get in now ?
6 REPLIES 6
Dannybear
Can you try using the pc web browser to login to the my.arlo.com web portal to access the account?
arlohater921
I have the same issue. The text verification takes about 5 minutes to receive, and the website allows 2 minutes. Classic IT design and incompetence issue.
Also, each time that someone leaves the iPhone app to pull the text code, the app closes, thereby requiring a new login, which requires leaving the app. This "loop" recurs until the user reaches the limit. This is a super classic "We did not test the app fully" issue.
Absolutely terrible IT issues.
Mpt3366
Did you ever figure this problem out?
PappaGeorgio
I’m having the same loop failure in the app.
>login
>sent one time code
>login page blank again (no place to input any codes)
>login again
>sent one time code again
over and over again.
Arvie
Having the same issue.  The app is closing and will send a code each time I tried to open it.  By the time I entered the code it is no longer valid because a new one has been sent again.
Tried using the web browser.   Getting  this  error message -  unused second factor auths limit reached.
Arvie
There is an option to use a different method.  Tried using my email and it works.
