Day 3 of no motion detection video recordings in the library.
System:
Base is VMB4000r3 @ firmware 1.12.0.1_28940
6x Arlo 2 Pro cams, 12x Arlo Pro cams, 2 Doorbells, 1 Chime
All worthless without motion triggers and no motion triggered video recordings
Status:
No motion triggers to Smart Things
Manual recordings are being saved to the library
Motion triggered recordings not saved to the library but are save to external USB disk
No motion notifications on iOS iPhone X (app v 2.7.7)
I was unable to stream live video but that was resolved yesterday - at least that's working!
As we all know, this new update firmware is creating big problem for everyone. This very scary and terrible, because the update firmware is done without the user/consumer's consent and the firmware is updated at midnight without anybody knows. Everyone try to thinks about this for the long run, and if they can to do this to you and me, it is very good for aftermarketing sales. Based on your account, they will know that your warranty expires, they can send a defective firmware to your base station, and make your base station useless, you will eventually purchase another base station or entire system. If everyone agrees with me, please stand up and provide your comment about Arlo product.
"Some customers"? Why don't you go ahead and say MOST or ALMOST ALL customers had an issue with this absolute total screw up. Please thoroughly test your software before releasing it.
1.12.2.0_2790 is what is listed as the firmware version for the base station.
Normaly, the process for adding device, force the update of base station firmware.
I tried that and it did not work. It is still asking to update the firmware.
Make sure that your system is set up for armed, and check off armed option.
You have a bad firmware (screw up version) that we are talking almost for one week now, it create a lot of problem for everyone. By now, your fireware should be rollback by Arlo company, if not, then ask the customer service to rollback, if they can't do it, then you have to return the base statation for replacement or puchase a new unit.
In the past two years, I have not gone at least a month wihtout one of the cameras going offline. I just replaced batteries and resynced all of them and this morning, I have two down with the dreaded message:
The engineering team has new field trial firmware available. We're seeking testers for this field trial with the best candidates being those of you who experienced issues with the last firmware release before we rolled back.
If you would like to help test the newest field trial release, please send me a private message with your email address and a confirmation and I will add you to the field trial.
Thank you,
