  • 1295 Views
bubba1234567
In the previous app one could remove clips simply by selecting
all clips and press delete. That is no lomnger possible so i must delete clips
one by one an that is disappointing.
Furthermore there is no way to partly close notifications anymore, that is
also disappointing. In short: i don't want to use Arlo anymore.
No you don't have to delete one at a time.  Press the three dots in the upper right of the "Feed" screen, and then select "Manage Events" from the pulldown.
I don't know what you mean by this.  Are you talking about muting notifications for a while?  Or something else????
bubba1234567
yes i mean muting notifications for a while. But now another issue came up..... suddenly there are no feeds anymore and i did not change a thing in the app. How can i turn that on again ?
  • What camera do you have?
  • Do you have a subscription?
  • Is the feed just empty, or are you getting a pop-up telling you it's a premium feature?
If the feed is just empty, then there are three things to check:
  • see if you can make a manual recording while livestreaming (and look for that recording in the feed).
  • double-check that you are using a mode that arms the cameras
  • double-check that you didn't filter the feed with "feed settings" and forgot to change that back.
That feature is still there:
  • press the profile icon in the upper left of the screen
  • press notifications
  • press mute notifications
It would be nice if there was a dashboard widget for this.
