- Replaced near flat batteries
- Camera upgraded to 1.2.10342
- Moved back to the camera position
- Did position test
- Now stuck in motion detection and camera postion test (busy)
- Resetting via open/close battery door
- Same problem
Also I have the same problem with another VMC3030 that was previously upgraded to 1.2.10342
Can i roll back to a more stable firmware?
Now concerned about the next battery change on the 3rd VMC3030 that is currently still working - on 1.2.16720
30 mins later that camera is now on 1.2.16720
and battery has dropped to 83% from new
Still stuck in position + motion test mode
two cameras out of action now after firmware upgrade
Did you restart the base? What are the LEDs showing?
Yes - restarted the base station a couple of times
Same symptom
Erased USB storage device and re-attached
Same
I may have fixed it by removing each camera from the subscription (5) and re adding.
Got an error saying -1 left
That fixed all execpt one
Removed and re added
Got no error the second time
All 5 cameras now working
Can do postiion tests and (Busy) goes away after 5-10 secs - success
Now monitoring battery usage again
Zardos,
At the time you originally opened this thread, Arlo was experiencing some issues that affected a small number of users. These issues have since been resolved: Intermittent issues with Arlo motion recording services
Are you still experiencing an issue?
Recording is working normally now thanks
However my issue with one camera draining a full set of batteries in a few days is still there
I have gone thru two sets of new batteries test that camera in the last couple of weeks and i do not have sufficient batteries to keep testing.
The other two H7s and one H8 seem fine
The problematic H7 is probably in the region of 4 metres from the base station
Swap cameras around to see if the problem stays with the camera or location.
Has netgear provided a fix for cameras being stuck in "motion detection test" and draining batteries. I have a camera with a dead battery after 1 week. I am out of state and unable to recharge the battery. This is unacceptable for a "security" system. Turning the camera on and off and re-setting the base station had not helped. Thanks for the firmware update, it made the system worse!
Yes. Still having the problem. Have turned camera on and off; rebooted base station. Battery completely drained after one week. I won't be back home for an other week, so security monitoring is zilch. FYI, I also had Arlo Q's which repeated went offline and had to be re-synched. Fortunately Costco has a good return policy, so I took them back. Now my Arlo Pros, which had been great for 10 months are not crap as well. Not a happy netgear customer, especially since the initial cost is so high.
