I'm concerned because I am not getting many motion detection alerts even when I know for A fact my pet is moving within range. Fresh batteries.
Also, why aren't register Arlo owners being automatically sent emails about security updates? Just read that Arlo Wirefree base units need to be updated to avoid a very bad hacking vulnerability and in order to do this you have to have to do a hard core default reset!!!
Anything I should know about the app being vulnerable????
This is concerning!!!!
Max_82,
Only one device can be logged in to your account at a time. Do you use both the mobile app and web client to log in? Or possibly two different mobile devices? Logging in on a second device will cause this message to be displayed on the first device.
We regularly monitor our products for security issues and we provide detailed information at www.netgear.com/about/security. In addition, if you have any security concerns, you can reach us at security@netgear.com.
CimGator,
How often do you notice this behavior? Is there any consistency surrounding when it occurs (does it happen only when both of you log in to your seperate accounts, do you only notice it when connected to 4g/WiFi etc.)?
Which app are you using? (iOS/Android)
I also have this issue. I am the only user and I can say with 100% certainty that I am NOT logged in from another device when this happens. Is there a way to track what IP address the other login is coming from? I'd like to know if this is a true security issue and someone is hacking into my cameras. This is highly concerning!
NickyB,
This could be occurring if you are using both the mobile app and the web client and leaving one or the other running while logging in. If you are 100% sure that is not the case, I recommend changing your password to ensure that unwanted access is not taking place: How do I change my Arlo password?
Not likely but if you're suspicious, change your password. Are you actually getting a message that you've been logged out due to another login or is it just that you have to log back in once in a while? Don't forget to set the Remember Me checkbox.
I get that occasionally but not often. Not sure what to tell you...
for me it's usu to much cofffee
Asmith90,
Do you use multiple devices to log in? This error could occur because you are logging in via the app when already logged in to the web client or vice versa.
Can't explain the issue from a single phone/app but recently ran into this when I happened to have a login on a browser tab and tried to login in another tab.
This has happened to me multiple times. I am the only one that knows my password. It happens on the PC. And I am definitely not using the mobile app at the time it happens. It is time for Arlo to address this security vulnerability.
How many devices do you use to check Arlo? It may be that one device is checking in the background. Just a guess..
I've been having the same issue since hooking the cameras up. I only have them indoors (bought the 3 camera set) to watch my elderly father, but when I'm elsewhere, I have been randomly logged out due to 'another device'... and that ended my use of the product. I am the only one with the cameras or access. My PC is off at home when I leave, so nobody else would have access. I was insecure about having wireless and internet streaming.. this only confirmed my issues. I don't like the idea at all that strangers are watching us in our home.. and nothing is completely secure. Thank you for asking the question though, at least I know I'm not the only one.
How often does this happen and on how many devices? You may need to open a case with support but try reinstalling the app first.
jesuslinares78,
Is there a way to set which of your login devices has priority?
I too have need this lately, but in my case the camera lights go on as if someone is watching and I know we are not logged in. I keep the LED lights set to off. I'm about to get rid of my Arlo because It feels as if someone broke into it and is watching us.
