"Firmware update in progress. Do not remove batteries"
  • 7 Replies
  • 4078 Views
  • 6 In Conversation
BTG
I've done the controller reboot. The other cameras updated the firmware, but the same one seems to be stuborn?
brh
@BTG@SuzyQueue,
If you have power cycled your base stations and that did not fix the problem, remove the batteries from the affected cameras for a few seconds the reinsert them. This will cause the cameras to reboot. You may have to resync the cameras one at a time and then you might have to try to upgrade the firmware again.
Brian
7 REPLIES 7
SuzyQueue
I'm having the same problem, and can't find an answer in the Arlo support.
brh
@BTG@SuzyQueue,
Brian
SuzyQueue
Thanks so much, Brian! That worked perfectly and I didn't even have to re-sync my camera. I really appreciate your assistance.
Sue
ant
Mentor
Mentor
I had this problem and had to do it about ten times for each original Arlo camera connected to their original base station.  😞
Tytn
Tytn
It says do not remove battery
If it's been over, say, 30 minutes, opening and closing the battery door won't hurt anything since the update failed anyways.
