"Arlo is unavaiilable" while setting up - Can't find a solution.
I see that this problem I have goes back nearly 2 years, from the on-line forums. Yet it still exists? I am trying to set up, and can't get past logging in and "naming" my system, then I get the "We're sorry. Arlo is currently unavailable. Please try again later" message. According to the forums, "engineering has resolved it" and "is still investigating to find a permanent solution." Ummm... it's been nearly two years. We do have prehistoric internet service where we are, but i can stream and go on line all the time. I have installed the app on my LG Android phone and an android tablet, and tried from my MacBook, all with the same response. Am I wasting my time with this system?
Rather than try it on the app, try it on the web ( more stable ) https://arlo.netgear.com/
I'm getting the same thing and no one can give me a straight answer
Welcome to the Arlo pit of misery....
Sounds like you chose the wrong camera unless the directions have changed recently. The wireless cameras don't scan anything - you just briefly press the base sync button (dont hold it for 2 seconds) and then use the camera sync button. You don't need to use the app or browser to sync cameras, only to claim the base.
Is the base a VMB3500? There's recent reports of the same issue. Swap at the store and/r open a case with support here:
I spent numerous hours and tried everything. Our IT guy at work even let me borrow another wireless router, which I just tried and still failed.
I'm done with Arlo and will buy something else. At least they don't need to ignore my angry post anymore..
Every once in a while this will happen as a one-time glitch and you can onboard your base station later. However, we have seen a surge in reports since our 1/8 update that is affecting the VMB3500 base station. Engineering was able to reproduce the issue tonight, and confirmed that a work-around for now is to factory reset the base station. Engineering is investigating the root cause, and we'll provide an update when we have one. For instructions on factory resetting your base station, see our article "How can I reset my Arlo base station to the default values?"
Except everyone here has followed the factory reset numerous times and the problem still exist, so it's not a "work around".
I tried everything and nothing works and cant get no help from support bairly understand them!!!!
I tried it on the web per your suggestion. It finds the base no problem, but when it askes me to name it and then click continue, I get an error meesage that states 'Aria account creation failed' and can go no further. FYI, the cameras are the plain Arlo camera, not Arlo go or any of the others. I did also try the other person's suggestion of using the sync button on the base, that does not work either.
Don't have the model number but this has been an issue for me. I have the Arlo app loaded on a Android phone.
Please help, I use these cameras to make sure my husband is safe due to a chronic illness.
When do you experience this error message? What version of the Arlo Mobile App are you using with your Android phone?
