  • 1084 Views
Slots
As I have read on several posts here - I too am now experiencing that one of the two cameras stopped recording - can watch live but no recordings in library - all was fine until two days ago. Suggestion on how to fix - obviously needed! Thanks
steve_t
Master Master
First, try a battery pull reset of the camera
Failing that, remove the camera from the system and then re-sync it. Then re-add the rule for it to any custom modes you have
Dz0
I'm so sick of removing my cameras and re-adding them.  This system requires constant care and feeding.  Unplug camera, remove battery, resync, delete and re-add.  Every month.  And you better hope you check every day cause it could just stop recording at any time and you wont know till someone breaks in and you dont have recording.  This is hands down the worst purchase I've made in recent years.
If anyone is within 30 days of buying Arlo, do yourself a favor and make the return for refund now.
steve_t
Master Master
What's happening that makes you need to remove and re-add the cameras? I have an Arlo Pro camera outside on a solar panel and I haven't touched that camera in nearly 2 years
