I have a premier account (which includes recording-saving). I've recieved email alerts of my camera triggered in my carport, but each time i went to my account-there was no recording???
what is the problem?
thanks
Rory
Is there a chance you have a filter set? Go to the library and click on the filter (funnel icon). Reset so all cameras are selected and save. The funnel should be empty/not filled in.
1. Ensure the rule for that camera in your current recording mode says that motion detection by the camera causes a camera to record. Weird things like ST integration can lead to that rule saying motion detection causes another camera to Do Nothing. So, first check the rule.
2. I find the easiest way to navigate detections is via the Device tab. Above the camera with be a number of triggers in a circle. Click on the number and it will show you the recordings for that particular camera.
I'll disagree with jguerdat and say that when you're in the library tab, make sure the funnel is empty. If you click on it and select all of the cameras, it will still show a solid green funnel. Reset should select no cameras and the funnel will be empty and you'll see all videos on your account
educatorkim,
Could you please post screenshots of your Modes page and also the Rules inside your main recording mode?
Sure, give the PC a go. Can't really be of more help without the screenshots
