not getting notications sounds anymore on my phone...just vibrates....did netgear do an update?
On the Android, click on the MORE or three DOTS in the upper right, settings are changed for the sounds/led/vibrate there ( in the app )
If it is grayed out, do a forced stop then clear the cache of the app, restart it
when i go to my settings...i see system but it is darkened out...it wont let me click into it....
You don't click on System (which is just a section header) - you look under that for Notifications and click on that.
thank you sooooooo much....i finally got it.....you guys rock
