set up my new arlo security system and no video's are being saved to the liabrary?
Are you in armed mode?
Perhaps set up your own mode and learn how to adjust the settings to meet your needs. You can set up rules for each camera and select motion sensitivity and recording duration. You can also set up cameras to trigger other cameras to record. Familiarise yourself with all the settings and functions and you'll be up and running in no time
i'm having the same problem. Really though Arlos totlaly suck!!!!!!!!!!!!!!!!
There is no solution and no amount of trouble shooting will solve the problem because Arlos totally suck!
i initially had problems setting up but once I got elevated to L2 support and they sent a replacement base station, we quickly got all 4 cameras going ok.
Although some features dont impress me (most noticeably lack of time stamp on recordings (though they are in library), I'm very impressed by quality of recordings and the fact that its totally mobile and weatherproof (as long as within range of the wifi of network the base station is connected by network cable to).
Not for everybody, not always smooth running as posts show, not cheap but a great solution for many.
btw, although many posts are from people having legitimate issues, many others are from people complaining the system wont do what it wasnt designed or advertised to (sunch as recording to drive connected to usb port for basic arlo)
Thats the view from here.
RonTheTech,
This could be due to old firmware on your Arlo base/cameras. Be sure you have the latest firmware installed and test again.
For more information on the latest firmware, see here: Firmware Release Notes
