Why all of the sudden the night vision is not working on my camera, I've had it for about 3 months and no problems and now it's so dark you can't see anything. Please help, thanks
Do the red IR lights on the front light up in the dark? I'm guessing no. Try a battery pull reset and see if it fixes it
also check the settings for the cam under Video Settings that the Night Vision switch is still in the ON position. Also how low is the battery level?
Yes, the red lights do come on but still too dark to see anything, I checked that night vision is on in the settings, and my battery is at 70%, I'm going to try and disconnect the camera then re-sync it to see if that helps. I'll will let you know what happens. Thanks
Very interested to hear the results of the re-sync, I'm having the exact same problem with one of my three cameras after only 3 months. I tried the battery disconnect thing as well to no avail, and ensured that night vision was enabled.
So what does one do if one has a single malfunctioning camera from a multi-camera system?
Jimbo
jrb5v wrote:So what does one do if one has a single malfunctioning camera from a multi-camera system?
Jimbo
I had to pack up the entire system and exchange it. Then I got an add on camera. Then another camera was pink so I exchanged the faulty one as the add-on camera so I didn't have to pack it all up AGAIN
A 3 month old system is going to require a case being opened with support.
Mike-Geneva,
You should not need to disconnect and resync regularly. How often are you noticing this behavior?
