overheat arlo wireless camera
  • 1 Reply
  • 4835 Views
Electrosynapsis
My camera became unresponsive, saying it was not online.
I  investigated this 4 hours later the IR was on (was lit up red) and would not turn off when in light and again showed as unresponsive.
I took the camera off the wall and it was hot to the touch. When I took the batteries out and touched them they were extremely warm. Also, this is an  in indoor never in the sun.
I then put the original batteries back in taken out from earlier and I recieved an email that my batteries are low.
I changed the batteries and it is working again.
Could this be a potential fire hazard? Why would the Arlo glitch to that extent? It is a camera and failed at doing what it is designed to do.
I am using energizer batteries to my knowledge.
If you were using the OEM batteries, IMO the chance of a fire is low..they don't have a high & long discharge rate ( like some li-ion cells in phones )
The fact that it was warm is prob the heat from the IR , which are light emiting diodes , and they can get quite warm if on for a long time.
I would keep a close eye on it , power button recycle the base just in case a command got messed up...and if it happens again it prob would be time to contact Netgear Support.
