  • 10 Replies
  • 9033 Views
Adksi11892
When using an iPad Pro the scrub facility when viewing footage in the library does not work at all, you cannot click on the timeline to move it.
10 REPLIES 10
This is with a camera that has a CVR subscription???
Adksi11892
No, this is when viewing a clip from regular motion detection event in the library.
I didn't understand what you meant by "scrub".
Are you just saying that you can't get the timeline control to work?  If so, I agree that it doesn't work in landscape with the iPad Pro - but it does work in portrait.
@JamesC , @ShayneS :  Can you please follow up?  It looks like this was fixed on the iPhone, but not the iPad.
Adksi11892
Ah yes it does work in portrait as you say.  If it can be fixed as you suggested for landscape that would be great.  Thanks.
ShayneS
Thanks for the report, it looks like the Arlo Development team is aware of the issue and a fix is coming soon. I'll provide another update soon.
ShayneS
Hi,
It looks like we have an update scheduled for next week. This should resolve this issue with the slider. I will provide another update as soon as I have more info to share.
Adksi11892
Yay, look forward to hearing from you.
ShayneS
Hi All,
This issue should now be resolved with the latest version of the Arlo mobile app v3.7
If you do not see the update in the App Store, you can remove and reinstall the app to the latest version.
Adksi11892
Hi, yes I updated earlier and it resolved the problem.  Many thanks!!
ShayneS
Awesome!
