Still am working on how to get simultaneous recordings collected in my library. I have 4 cameras; 1 in kitchen, 1 in backyard, and 2 in living room. They do not record and store date in my library simultaneously. i would like to have a library for each separate camera. Still haven't found that answer. Not even sure it is possible.
Not possible at this time. The closest you can get is to click on the numbered circle for each camera in the Devices tab which will filter out all other cameras for that view. A bit clunky but works. You can also use the filter in the library (funnel at the top of the view) to do the same thing.
