arlo wire free cameras appear offline
hi My cameras appear off line I tried everything and still not working I need help please
I tried that and still appear of line
the first three light are green but still not working
sanson,
Are you still seeing this behavior? It could be depleted batteries resulting in the camera showing offline. Try a fresh set of batteries to further isolate the issue.
This is happening to me, I did replace batteries also. Power cycle, reset, delete all cameras, sync per step by ste, nothing appears on app or PC, please help I don't know what else to try. MODE is "offline" and until I deleted the cameras one by one they read "your device appears offline"
Restarted everyting so many times. Happy green lights all solid except for when syncing camera that never shows up, then it blinks as per instructions.
You didn't mention using the reset procedure. Use the reset button on the base until the LEDs flash amber. Remove all devices in Settings, My Devices. Use the Add Device button on the Devices tab to add the base and sync cameras. Update any firmware following any prompts shown. Check the firmware versions in Settings, My Devices, your devices and compare them with those reported in the Release Notes section here. Does it now work properly?
