i have 5 cam I want to add more cam in pro. ????????? and The purchase another device with 5 came But the program does not accept upgrade your account .
I think your app is hosed. Reinstall it to fix the display corruption.
i try from my pc too same problem
Try power cycling your base.
i try this and Does not work the same thing.
salwan wrote:
Meaning?
salwan,
It sounds like you are describing an issue with purchasing a subscription? What is preventing you from doing so? Do you get an error if you attempt to select another plan?
I have purchased a new product . And surprised Lists upgrade If you notice in the image above I can not account upgrade
salwan,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
