how to replace broken glass on camera
My outdoor camera fell onto the pavement and broke the glass. I cannot seem to find where or IF you can replace the glass. Need help in finding where to get it or need to know if I have to replace entire camera. Thanks!
TBMK, there are no parts available... try and contact Netgear Support.
Since it's already damaged, I'd try wiping some silicone rubber over everything but the lens and PIR motion detector. This may seal it sufficiently to keep it working for you.
