how do you delete more than one item at a time?
Select one by holding your thumb on it. After you've done that, you will notice a change on the top right of your phone. There's a new box that looks like a grid. Press that and it will select all of your videos. Then delete.
Great answer, perfect and precise! Thanks
The solution was for an iPhone. It does not work on a web browser. So how does one delete more than one item at a time on a web browser. A better question is how does one delete "selected" items at the same time, i.e., a mass delete?
on pc browser, when you;re in the library, in upper right hit select. then you can check off any or hit select all to delete from that date
