  • 5 Replies
  • 6214 Views
  • 4 Likes
  • 6 In Conversation
tamarareichel
how do you delete more than one item at a time?
Clairesly
Select one by holding your thumb on it. After you've done that, you will notice a change on the top right of your phone. There's a new box that looks like a grid. Press that and it will select all of your videos. Then delete.
5 REPLIES 5
Clairesly
DenLizB
Great answer, perfect and precise! Thanks
gdvalde
The solution was for an iPhone. It does not work on a web browser. So how does one delete more than one item at a time on a web browser. A better question is how does one delete "selected" items at the same time, i.e., a mass delete?
manfredz
Hero
Hero
on pc browser, when you;re in the library, in upper right hit select.  then you can check off any or hit select all to delete from that date
Or don't delete at all. Too many folks have wished they hadn't deleted videos they then wanted back. There's currently no harm in leaving everything in the library.
