  • 8 Replies
  • 7500 Views
  • 5 In Conversation
sethm1
Firmware version: 1.2.4941
Firefox version:  46.0.1
Seems the last week that when I attempt to view Live my cameras - nothing happens.
But mode settings, Library files, & Pan & Zoom under settings all works fine.
Internet Expl works just fine.
Loaded question - but any suggestions with FireFox?
sethm1,
You might also try a fresh install of your Firefox browser. I have tested this using the version of Firefox you indicate above and have had no issues with Live view.
8 REPLIES 8
Some times it's fine, sometimes, not,.... been this way from the beginning.  There are so many variables in each computer with updates,etc there is no telling.
Biggest is with flash , so check those settings first.
sethm1
yes, this last week when I opened the Arlo page there was a msg to update Flash - which I did, but that did not seem to help.
sethm1
Enabled Silverlight plug in - but that did not make a  difference.
Silverlight won't help. Live view requires Flash - most other stuff works fine without it. Maybe uninstall Flash and reinstall.
sethm1
Uninstalled Flash, rebooted PC and reinstalled Flash - still no  fix.
Guess will use IE and my iPad.
sethm1,
kitkathouse
Mine crashes every time I go to watch the email indicated video.
If I reinstall firefox (i have updated it) will I lose my bookmarks and passwords? That would be awful!
should I use chrome, safari, or explorer instead?
You can try restarting FF with add-ons disabled to see if that helps first.
To reinstall, make sure you have Sync set up to save your settings (also useful for setting up a new device to use FF with the same settings). That should allow you to uninstall and reinstall FF with no issues - just use the sync feature to recover your settings.
