I bought a new system a week ago with 4 cameras. One camera went offline after a few days and now will not sync at all. The sync light on the camera does not come on at all when trying to sync. The batteries are OK, as the blue light comes on for a few seconds when the batteries are taken out and put back in. I've tried rebooting the system, three of the cameras sync fine, but the fourth does not. As the slow flashing blue light fails to come on when the sync button is pressed, I'm assuming a faulty camera. Please advise.
I took it back to the store and got a replacement
Create an actual trouble ticket. The forums help but don't necessarily get you action such as replacement. Alternatively, contact the seller and see if an exchange can happen.
Good afternoon Keefo,
Were you able to resolve the issue with the camera that was not syncing properly? If so, what (if anything) did you do to resolve the issue?
Your feedback is greatly appreciated and will benefit other community members!
Thank you for your post!
Best Regards,
Christine
Arlo Team
____
Please click
KUDOS or REPLY if you found this helpful.
Comp,
It sounds like heat off the driveway may be causing the false triggers. You could try positioning the camera so that it is angled away from the driveway to see if you get better results. It also may be beneficial to swap it with one of your other two cameras to make sure both cameras return the same results if you haven't done so already.
Regards,
How do I start a trouble ticket? My night vision is constantly going out, I undo the battery door, and only sometimes that fixes it (happens every 2-3 days).
DJJimmyJam,
After performing the necessary troubleshooting steps and you are still encountering issues, it is best to contact our support team. They'll be able to better assist in further troubleshooting and resolving your issue.
KristynM
Arlo Support Team
I have a bad camera that only films in black and white. sometimes it turns all red. I purchased a 5 camera system from Amazon. how do i get a replacement? I only need one camera replaced.
KyleF,
Please contact the Arlo Support Team to resolve this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
