I have had my system setup for a couple of months, worked flawlessly. One of my cameras needed new batteries, I replaced the batteries - but the camera would not resync. I messed around trying to get it to sync with the base unit, but nothing. I thought, well - let me try with another camera. I removed one of the other cameras and then tried to sync it as well. Same thing, fails in trying to sync the camera and the base.
Thoughts/ideas?
The power and internet lights are both on solid and they are green. I can restart the base unit from the app on my phone. So, I know I have connectivity.
I have no cameras attached now. I can't get any to add back either. When I press the sync button on the base unit, the camera light flashes green. I then press the camera sync button and it flashes blue. Then, the camera will start fast flashing an amber light. They are just never syncing.
What the heck?
I have removed and added, and removed and added the base unit to my account multiple times. The cameras remain steadfast in their reaction and do not want to sync.
You're just briefly pressing the base sync button, right? If so, open a case with support using the Contact Support link at the bottom here.
I have a case currently open with support. They are being a bit slow to resolve and there is only so much of removing and adding the base station I can stand. Repeating the same thing and expecting a different result when nothing was changed is not productive.
That's why I reached out here in hopes someone else ran across the same issue and knew a fix.
Thanks.
Not sure what happened, but somehow my account needed to be reset. Once that was done, ez-pz to sync my cameras!!!!
So, I have two base units, one with four regular cameras and the other with three regular cameras and a pro camera!
Back to working fine now!
I suspect he means that he removed all devices from Settings, My Devices and started fresh.
Kewl. Did you reuse the same email address?
