Unplugged DVR & plugged in again; cams still not recording. Cams are working.
Switched up Mode settings; no recording.
Pls advise. TY.
Are the running men in the Cameras tab black or gray? If the latter, try using the Armed mode for testing.
I also have the same problem with my 2 camera set up. I receive notifications that the cameras have detected motion but nothing has been recorded, also I cannot get a live feed. I wonder if this is related to the IOS software update 3 weeks ago as a friend of mine with an identical set up is having similar issues
I also have the same problem with my 2 camera set up. I receive notifications that the cameras have detected motion but nothing has been recorded, also I cannot get a live feed. I wonder if this is related to the IOS software update 3 weeks ago as a friend of mine with an identical set up is having similar issues.
Same thing if you use a browser?
jguerdat wrote:Same thing if you use a browser?
I tried accessing the live feed from a browser (Google chrome and internet explorer) with no success. I introduced another camera running an older firmware version (1.2.2688) and it works fine!. That would suggest a possible software issue. The problem cameras are running version 1.2.4941 - is there any way I can reinstall the older version? The cameras are hardware version H7
What happened when trying to use a browser? Was there an error message?
The firmware version is automatically updated and can't be changed by the user. It's a "push" from the servers.
The fastest way to try to get around this is to make note of all your settings and modes/rules followed by deleting all devices from your account in Settings, My devices. Use the reset button on the base and press until the LEDs flash amber. Let the base stabilize with two green LEDs (power and Internet). Use the Add Device button on the Cameras tab to add the base back in and then resync the cameras. You'll then have to set up any settings you used previously as well as modes and rules. That should set things right - if not, you'll need to create a trouble ticket for additional help and possible RMA.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
