  • 2 Replies
  • 4154 Views
dlinknext
It would be WONDERFUL if these things worked off line because mine are continuously offline.  They worked great for about 2 weeks and now they are constantly shutting offline.  Finding them to be a huge waste of money and serve no purpose because everytime I need them they are once again, OFFLINE!!!!   I hope they actually read these comments and questions and problems and I really hope they fix them before adding anything else.
dlinknext,
It sounds like you could be having an issue with WiFi interference or poor signal strength due to range that is causing your cameras to drop offline. Do all of your cameras drop offline or is it specific to certain cameras?
To further isolate, consider relocating the cameras that are behaving this way close to the base station and test to see if you get the same behavior.
Drake3287
Luminary
Luminary
I've had the same problem and just wondering what you did to get them back online. Did you have to delte the camera and reactivate with the base station like I did? My camera is very close to my wi-fi router and has a strong connection so I'm not sure what the issue is.
