How to turn off funky text messages
  • 2 Replies
  • 3355 Views
JasonRay
After replacing batteries in the camera, I started receiving a funky text message in addition to the pop up notification. How to I keep the pop up notification and turn off the following text message:
1 of 10
FRM:alerts@arlo.com
SUBJ:Arlo Has Just Detected Motion
MSG: This Just InaΔ¿ body{
(Con't 2 of 10
background:#EEEEEE; padding:45px 5%; margin:0; position:relative;
(Con't) 3 of 10
display:block; font-family:Arial, Tahoma, sans-serif; cursor:default;
(Con't) 4 of 10
line-height:normal; } a,img{ outline:none; border:none;
(Con' 5 of 10
} .fixed-table-layout{ display:table; table-layout:fixed; }
Mo
I don't know the specific reason for this but I'd try the following, not necessarily in this order:
- power cycle base
- restart phone
- try a browser
- reinstall app
Are you using your phone number as an email adress to get text ??  ( since Arlos only do push and email, not text )
The only time in past I have seen similar is the provider failing to strip out the html when converting to SMS
