  • 2923 Views
James14
I recently moved my base station to one location to a next.  The system reads "offline", but the cameras are recording and I am getting occasional messages on the app.  I have read the threads on this issue and are wondering which way to go.  System reset?
easy and safe first is a power button reboot of base
James14
Tried that initially, no luck.  Strange thing also is that the cameras are only recording if the camera is physically moved, not if motion is detected.
Ok.. next is a pain but should work... system reset
Go to SETTINGS, pick camera, use REMOVE DEVICE
open and close battery door
After all cams done
Hold in the RESET button for about 10 secs till the front leds flash
Let the base reboot ( a min or two )
After base is back with power and internet, resync cams as when new ( remember quick push only on base sync button )
