6 REPLIES 6
I assume this is for the cameras? If so, I haven't received that push yet.
-Robert
The update only appears to be for the base station. The camera firmware remained the same.
Showguy wrote:The update only appears to be for the base station. The camera firmware remained the same.
correct... they new s/w was for the base only; curent base version is 1.6.0.3643
The cam s/w did't pass approval and remains at 1.2.2688
Haven't seen any notes, but now you can stream 5 cameras at same time ( use to be 4 )... try it.
Tom.. Good to know bout' 5cam stream.. Thnx!
I got the base updated but not the cameras.. Hopefully theres some fix in this new fw..
