When you zoom in on the picture ( in camera settings ), it shows the area you will see in videos/jpgs.
But, it just expands the picture to the viewing screen size so there is an apperance of loss of rez.
The best thing to do for that camera is to set the video quality on ' best video ' over Optimized.... there is no other adjustment.
Edit: deleted.
It's a digital zoom, not optical. The difference is that digital zoom simply crops out the outside area, making what's left appear bigger. However, you've instantaneously lowered the resolution. Since there's no optical zoom possible, the best we could hope for is an update that would allow less compression of any video (ever noticed the compression artifacts with moving objects like leaves/branches/etc.?).
There are IR illuminators for night vision. Set your mode to All Motion On and walk in front of the cameras in the dark. You should see a dull red glow from the camera when motion is detected. You can verify recording by looking at the Cameras view and see a camera and running man in red.
