- 2
Too late, sorry. I have already returned all 4 of my Arlo Pro cameras to Best Buy, and have purchased a different camera solution.
First, we need to know exactly what you tried. Did you reset the base by pressing the reset button until the LEDs flash amber? Did you remove all devices found in Settings, My Devices and then used the Add Device button on the Devices tab to start fresh? Did you contact support and open a case?
I personally completed all of the actions you mentioned and more, i have even been sent a new hub by support. This is a constant issue that is being reported by many people and the constant reset, remove devices, open camera, close camera steps are frustrating as we shouldnt have to be doing this.
Yes a case has been opened and still no luck.
Could it be the ISP? If so what should i be asking them?
The batteries are simple - use good quality OEM-style CR123 batteries. And the Pro cameras have mics in them for listening to your wildlife's noises.
Please help me get my arlo back will not reset, keeps saying add a device and when I do what it says it will not accept it.
Did you reset the base by using the reset button until the LEDs flash amber? Did you remove all devices in Settings, My Devices and THEN use the Add Device button on the Devices tab to bring the base back into the account?
The updates can occur in place - no need to move anything. Updates sometimes cause issues for various reasons, such as being incomplete due to battery level, network interupption, etc. so may cause the need to troubleshoot, resync, etc.
Seems no one really has an answer for what is going on here. you would think Netgear would stepup and offer a solution just bought mine yesterday, did sync this morning set cameras around basement 15 feet from base. One camera quits working sync it then another quits, it is always 1 out of 4 want work. IOS app want work just says wait a minute never lets you connect. With all these problems just out of box throwing this stuff in box and heading back to Best Buy for refund.
I finally got 3 cameras to synch (I was forced to do the factory rest on the base unit to be able to synch more than 1 camera) and everything appeared to be coming on line. I got the message that the cameras needed a firmware undate and after that, the system never would come back online.
- 2
