  • 3474 Views
ArloKevinR
So after playing with the system, and reading
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-adjust-Arlo-video-recording-length/ta-...
I just want to make sure that I read it correctly
There is NO way to adjust time setting on "Schedule" mode, only Armed? If so that is pretty stupid. 10 seconds doesnt usually capture much, and its another 10-30 seconds before the camera reams itself.
Is this JUST Arlo, or is Arlo Pro the same?
What about the Arlo Qs?
Other than the power cord, does Arlo Q (and Q plus) broadcast wirelessly? Can the be hardwired or do I need to run an outlet to where I want them? How long is the power cord?
TYIA
Schedule isnt really a MODE tho it appears in that section...what schedule does is turn on or off a MODE based on time...
So you are correct, you can't ajust the record time in schedule...you do it in the actual MODE that you use in schedule
Arlo, Arlo Pro, And Q all work the same way as mentioned above
The Q cameras use your HOME WIFI to connect so they are wireless in theat respect... while the Arlo/Arlo Pro must connect to a base unit.
The Q uses ac power via a USB adapter to a micro usb plug ...so yes you need an ac outlet within the 7-8ft of the cord lenght
ArloKevinR
The issue I'm having is that I have gone in to "armed" and changed setting to 60 sec, yet the camera still only records 10 seconds at a time in schedule mode
Shouldn't it be recording 60?
Many fail to SAVE... after you changed the slider, you must use the BACK on the top left of page and on the bottom of previous page is SAVE
PS make sure the schedule is turned OFF when you do it too
( pics don't show till approved for others )
