Wirelessly Connect the Base Station to the Modem
This camera system will be used at a holiday house. The guests have access to the modem (in case they need to reboot it) but I don't want them to have access to the base station. How can I wirelessly connect the base station to the modem, so that it can be kept in a lockable cupboard?
Your only choice would be to use a WiFi extender so the base plugs into that. Of course, that can add some complexity and possibility of issues with a router restart. It generally should work fine but the possibility exists. Another approach would be a long Ethernet cable so you can reposition the base as desired. Either approach has its own plusses and minuses.
