  • 5 Replies
  • 4224 Views
stpeter
I read in a review that Arlo cameras will run on 2 batteries but without night vision.  I don't need the night vision feature for our application and would like to conserve batteries if possible.  If this will work, which 2 battery positions should be used for this?
5 REPLIES 5
Noel_Flantier
It'll work, however with low battery level and without night vision as you said. I don't recommend you to do it as the motion sensor might also be affected and not detect motion that well
The Arlo cam will run on 2 cells ( the two sets are basically in parallel to double the available current ).
It will NOT conserve batteries if run on just 2.  The IR is NOT disabled on 2 cells and the camera will function but for a MUCH shorter time as the current draw is to high for just 2 cells.
Sincity
Does this mean in theory it will run on a 5V USB phone charger if I can solder the AC adapter leads onto the board?
OEM batteries are 3.2v each for 6.4v and rechargeables are 4.2v for 8.4v
I think you be a bit low as usb is just 5
Sincity
^Tks. For some reason, I thought they were 1.5v volts each.
